Use this procedure to enable trace for IPv6 DHCP Relay and enable IPv6 forwarding trace.
  1. Enter Privileged EXEC mode:
    enable
  2. To troubleshoot IPv6 DHCP Relay, you can enable rcip6 trace messages using the following command:
    trace level 66 3
  3. You can also enable IPv6 forwarding trace using the following command:
    trace ipv6 forwarding enable <all|debug|error|info|pkt|warn>
Enable rcip6 trace messages and enable IPv6 forwarding trace:
Switch:1>enable
Switch:1#trace level 66 3
Switch:1#trace ipv6 forwarding
